HELP!
Keenanzie
Help me please.
I need a solution to fix this.
T_T
TIA
System
  • CPU
    Ryzen 5 3600
  • Motherboard
    Asus TUF GAMING b450M plus II
  • RAM
    32gb 3200Mhz Hyperx RGB
  • GPU
    Zotac Gaming GTX 1660 TI
  • Case
    SilverStone FARA R1
  • Storage
    256gb SAMSUNG 970 Evo Plus m.2 NVME SSD + 2tb HDD
  • PSU
    EVGA 500 BR
  • Display(s)
    24'' AOC 144hz IPS Panel
  • Cooling
    DEEPCOOL GTE V2
  • Keyboard
    CHERRY G80 3000
  • Mouse
    HYPERX Pulsefire FPS PRO
  • Sound
    SADA 2.1 Speakers
  • Operating System
    Windows 10 Professional
  • Laptop
    ACER Nitro 5 i5 8300H + GTX 1650
13 minutes ago, NinJake said:
Have you tried updating it by right clicking and searching online for the driver?
https://www.sweetwater.com/sweetcare/articles/how-do-i-update-my-pcs-usb-3-0-chipset-drivers/
I have tried it, but did not work. I've tried also reseating everything( cpu, ram, m.2, sata, all connectors) but did not help. I have tried also using two different drives m.2 and sata with installed windows but it resulted same problem.
System
  • CPU
    Ryzen 5 3600
  • Motherboard
  • RAM
  • GPU
  • Case
    SilverStone FARA R1
  • Storage
  • PSU
    EVGA 500 BR
  • Display(s)
  • Cooling
    DEEPCOOL GTE V2
  • Keyboard
    CHERRY G80 3000
  • Mouse
  • Sound
    SADA 2.1 Speakers
  • Operating System
  • Laptop
Did you check your motherboard's support page for the driver? You could also try to find the driver from Intel's website. Just be careful as you should NOT load the driver from external/removable media. (at least that's what I saw from a few other searches)
You'll want to download the driver and save it to your desktop and then load the driver from there if you can manage to find the right one. It should be related to your 7th gen processor.
23 hours ago, NinJake said:
You can try the chipset driver here.
https://www.asus.com/supportonly/B250M-KYLIN/HelpDesk_Download/
EDIT: as long as your system is the one that's in your signature, if not.... what are the current specs of this system you're having trouble with?
i will try tonight, thanks!
System
  • CPU
    Ryzen 5 3600
  • Motherboard
  • RAM
  • GPU
  • Case
    SilverStone FARA R1
  • Storage
  • PSU
    EVGA 500 BR
  • Display(s)
  • Cooling
    DEEPCOOL GTE V2
  • Keyboard
    CHERRY G80 3000
  • Mouse
  • Sound
    SADA 2.1 Speakers
  • Operating System
  • Laptop
the specs are in my signature. 🙂
System
  • CPU
    Ryzen 5 3600
  • Motherboard
  • RAM
  • GPU
  • Case
    SilverStone FARA R1
  • Storage
  • PSU
    EVGA 500 BR
  • Display(s)
  • Cooling
    DEEPCOOL GTE V2
  • Keyboard
    CHERRY G80 3000
  • Mouse
  • Sound
    SADA 2.1 Speakers
  • Operating System
  • Laptop
