Need help with partitions - NTFS and FAT32 on same drive
Mark Kaine
So I looked this up, I understand its possible,  and I have an idea how to do it, but im not sure about the downsides and if the process can be reverted later.
The situation is: i have a 1TB NTFS drive with 250GB free and i want to make a ~200GB FAT32 partition on that so i can use it to restore a PS3 system backup... and the PS3 can only read FAT32... and it also needs to be "MBR" from what I gathered.
So how I do this and is there any danger to the data already on the drive and how easy is it to revert the process,  ie make the whole drive NTFS again (if needs to be)?
That's besides I don't know if PS3 will read such a "hybrid drive" but I think it should as long it sees a FAT32 partition.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
That method has the risk of data loss.
I did some extreme software mods on my PS3,
And one of them was adding NTFS support to the PS3.
But the best way to backup the console is take the HDD,pop it into a PC,and do a sector by sector backup.
You will need the:
eid_root_key
That's the encryption key of the PS3 drive (The console automatically encrypts the boot drive)
You will need PS3TOOLS for Windows or the equivalent tool in linux in order to read the drive of the PS3.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
You will need the:
eid_root_key
I already have the backup, its on my laptop, but now I need a medium that the PS3 can read, but I see this would be a work around as I still have the original drive with the PS3 system so I *could* use that method to copy everything to the new drive - I suppose.
However this console has OFW, its a super slim, would that still work or do I need CFW for this eid_root_key thing?
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
You need CFW in order to get the eid_root_key.
I already have the backup, but now I need a medium that the PS3 can read, but I see this would be a work around as I still have the original drive with the data so I *could* use that to copy everything to the new drive - I suppose.
If it's the backup you do from the console it self know that it doesn't backup everything.
Some developers blocked the option of backing up the save files of their games.
You can still pop the PS3 drive into a PC and do a sector by sector backup up but without the eid_root_key you won't be able to access the data since it's the encryption key.
You will still be able to use this backup as long as the PS3 is alive.
So if you do the backup from the console itself i recommend to take an empty drive and format it to FAT32 and use that for the backup.
Right, I mean that would be the easiest option,  but I don't have an empty drive, hence I thought i could make a fat32 partition on the 1tb drive, but I don't want to lose the data on it, obviously,  I still think it should work - but im not sure...  i mean the ps3 won't be able to read the ntfs partition so it should be safe? 🤔
ps: just to be clear, I have the backup,  i need to get it *onto* the PS3 now, it would be easy to just copy it, but that won't work because the PS3 won't read a simple copy, it needs to be done with the PS3 restore thing.... basically I need a new hard-drive,  just to do that... its silly. 🤷‍♂️
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
It's not safe,the risk of data loss exists.
Yeah, I figured as much...
I guess I'll have to see about getting a bigger drive for my pc then I can do the whole PS3 swapping and backing up thing.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
