System specs
  • AMD fx4100
  • asus M5A78L-M/USB motherboard
  • GTX 660
  • 8GB of corsair XMS3 RAM
  • Arctic Cooling Freezer Xtreme Rev.2 CPU Cooler
Hi,
I have recently decided to delve into the world of overclocking and I have come across task manager reporting a different CPU frequency to CPU-z, core temp and AMD overdrive (which i used to change the multiplier as I like GUIs). I am wondering if this is normal or if I have done something wrong and if I should go into the BIOS and OC my CPU that way.
Cheers :)
Task manager displays core speed? That must be in win8.
Cpu-z is almost always correct in everything it displays. I just wish it had a Gpu-z and HWMonitor built in...
Always use the bios for overclocking unless you have a real good reason for software overclocking. Just ask questions about the bios/uefi around the forum or Google.
Its common in windows 8 that is displays the wrong Cpu freq' in task manager. Tends to be the default speed of the cpu but there has been times when it windows 8 task manager has reported higher/lower cpu freq'.
I would stick to CPU-Z for true readings of Cpu freq' . Overclocking is best done in the bios/uefi but low overclocks are ok via software GUI's. Best to do large/extreme overclocks in the bios/uefi only.
MB: Gigabyte Auros Gaming 7 Z370 Cpu: Intel i7 8700K @ 4.8ghz Gpu: Gigabyte GeForce GTX 1080 G1 Gaming OC 8GB Ram: Corsair Vengeance LPX 64GB DDR4 DRAM 2400MHz  Psu: Corsair RM1000i
Ssd's: WD Green nvme m.2 512gb (boot), 480gb (Steam), 480gb (Uplay) and 480gb (Origin)  Cooling: Corsair Hydro Series H115i 280mm
 Case: Corsair Obsidian Series 900D Monitors 1: Asus pb287q @ 75hz
