So, you should have 2-4x2 (8-pin) CPU EPS power cables provided in the box with the power supply, right?? Combine the 4pin connectors to form a 8-pin block and plug this into CPU_PWR1. CPU_PWR2 can be ignored as this is for extreme overclocking/LN2 overclocking and is not necessary for you unless you are.
If you do want to plug the CPU_PWR2 cable in, just use 1 4-pin connector and plug that into this header. Either one of this 4-pin blocks should fit as long as they are aligned properly. Don't force it.  The rest can be plugged into the modular rail for CPU power. These connectors to the PSU should be on the left corner closest to the cables going to the PSU.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1382881-cpu-power-cables/#findComment-15059870
