I have a dual system and wondered if my case airflow could be improved. The rear exhaust has started to give off a death rattle and will need replacing soon. Given it will be a pain to rewire, is it worth adjusting the setup?
The AIO has 120mm fans, the rest are 140mm. All fans are Phanteks. See image below:
My thinking is to change the top fan to exhaust system 1(red) instead of system 2(yellow) and have to 140mm intake and exhaust fans controlled by system 2.
https://linustechtips.com/topic/1382038-dual-system-airflow/
The cooler at the top left looks to be moving air upwards, opposite of the arrow.
If temps and acoustics are fine, there's no need to change anything.
https://linustechtips.com/topic/1382038-dual-system-airflow/#findComment-15054286
ya the itx cpu cooler is going twards the mb. the top fan not doing much. i just move it to the back.
https://linustechtips.com/topic/1382038-dual-system-airflow/#findComment-15054422
Ah, you spotted my deliberate mistake.
As the ITX system runs 24/7 I want to quieten it down a touch so will change the front and rear 140's to run off the ATX system and have the top fan vent warm air from inside the case.
https://linustechtips.com/topic/1382038-dual-system-airflow/#findComment-15054859
