Display Port not showing BIOS with GTX 1080
Jawzeph
Go to solution Solved by Kilrah,
I recently got a used GTX 1080 Gigabyte OC edition and I noticed that when working with display port, my monitor doesn't pick up any signal on startup. On the other hand, hdmi works flawlessly. So I have to start up my pc with hdmi plugged in and then switch the cables manually for DP to work properly. This however wasn't the case with my old GTX 1060, so what is the problem here?
GPU: GTX 1080 Gigabyte OC
Monitor: AOC 24G2
Motherboard: Asus H370-A prime
OS: Windows 10 Education
F@H
GPD Win 2
  • 6 months later...
