I'm thinking of getting a 7870 from AMD,would that be a good buy?
yes. or else i wouldn't run it :9
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
https://linustechtips.com/topic/1381-radeon-6870-worth-it/#findComment-20587
I have seen a 6870 for 120 dollars on newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16814202020
If you can get one of those or two that would be a great performer for the price
If you can't get a 6870 for less than 160 get a 7850 or 660 then are cooler and perform better
https://linustechtips.com/topic/1381-radeon-6870-worth-it/#findComment-20897
I have a 6870 from Sapphire with a i3 2120, 4GB RAM and it is still a very good card. Far cry 3 on 1080p everything on high (except post processing) and I got steady 50 FPS
Like said before me, if its over 150 euro I wouldn't do it. Then better get a 7850 or even better 7870 because they are just much faster
I got mine 6870 for 100 Euro so it was a clear buy for me.
XEON 1230 v2 / AMD R9 280x / 8GB DDR3 / Adata XPG SX900 256GB SSD / Corsair 300R Side Window / Corsair CX500M / Corsair M65 Green
https://linustechtips.com/topic/1381-radeon-6870-worth-it/#findComment-24696
