Hey,
I bought the Creative A250 speakers yesterday and actually wanted to set the subwoofer on my floor but because of my high desk the cables wouldn't reach it. I didn't want to set it on my desk so I decided to put it on my PC which is under my desk. Now to my question: Could anything happen to my PC? I don't listen to music at an extremely high volume but at a medium volume quite a bit of vibration is passed on to the case...
Thank you,
simx
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/
The only thing I could think of is subwoofers have a large magnet inside of them. Large magnets near hard drives never ends well. But I cant imagine its a particularly powerful/large sub so it should be ok :)
But then again big vibrations are not all that great for hard drives either.
Quack 🦆
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834273
HDD might not work long as it could, because of vibration, but i am not sure if it even shortens the life of it, but other parts will be totally ok. :)
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834279
Thats true but it has also been seen that magnetic field in ur case can help in cooling... :)
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834301
I would worry about. A the hard drives, B the case rattling, C cables, and cards, screws etc working loose over time.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834320
Having a CRT monitor near a sub can make the monitor all messed up.
Large vibrations could potentially create errors on your hdd and ruin your data.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834382
best thing is to get a short extension
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1834454
I could, of course, also set it on my desk but that isn't what you wanna do, is it?
It still works but not as well. I for one never really noticed the difference xD
https://linustechtips.com/topic/138049-set-subwoofer-on-pc/#findComment-1846228
