Specs:
(LAPTOP)
GTX 1060 6GB
I7 6700HQ
16GB RAM
i just cant figure out whats going on, i literally tried everything possible everytime i enter a game im just getting 10% usage and for some reason my integrated gpu is getting more usage like 36%, it had several serious problems in the past and i could not take it anymore cause it sometimes wont even turn on, i gave it to some guy to fix it and he installed windows on the smaller drive which is only 120 gb but that isnt the issue, after i got it the gpu usage was very low and i was getting low fps.
How do you monitor GPU usage ? With Windows Taks Manager ? Windows Task manager does NOT show proper GPU usage of DX12/Vulkan games check in something like GPU-Z or HWInfo.
R7 9800X3D, Arctic Liquid Freezer III 360 ARGB, ASRock X870E TAICHI, Kingston FURY 64GB (2x32GB) 6000MT/s CL30 Beast Black RGB , Gigabyte RTX 4090 Gaming OC, Windows 11
i used task manager thought it would not really show me the proper usage so i used msi afterburner
