Rx 570 , using the wrong fans . Help please ?
I will link the fans that I bought of Amazon. And try and link my gpu also
But I have a red dragon power colour rx570 4gb , and the fans died so I bought some new ones from Amazon ,and my dumb ass didn’t check the mounting hardware . It’s not the right ones for this particular card . Is it still safe to use by just jamming a few screws through the heat sink fins?
GPU Cooler FDC10U12S9-C Graphics Card Fans for HIS RX 570 IceQ X/Turbo RX574 RX470 RX 480 Video Cards Cooling (90mm Diameter 40mmX40mm Pitch Blue) https://www.amazon.ca/dp/B08NZGRD3S/ref=cm_sw_r_cp_apip_wpeEm9WIvLBjO
https://linustechtips.com/topic/1378624-rx-570-using-the-wrong-fans-help-please/
Just send them back in and/or get the proper ones. These fans are high RPM, it will be violent when one of the blades disintegrate.
