so today i was watching LTT(as always)and my pc dies and restarts all of a sudden, should i be concerned?
i have a felling its a power supply issue but its a 450W and idk what 80+ thing it is caz its supper old and my pc parts are hella old meaning they wont take alot of power right?
i have a pentium 2180 at 2GHz and 4gb ddr3 ram with a HHD with 1 stock cooler and no exghost or intake-
https://linustechtips.com/topic/1378011-pc-power/
Unless it keeps happening frequently, I wouldn't worry.  I doubt that Linus would something into his videos that breaks hardware, though I wouldn't be surprised if amazon did with their games.  And your computer doesn't suddenly overpower the PSU, unless something is broken, and in that case, you'll find out soon enough.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024655
I agree with heimdali. If it doesn't happen frequently, it's probably not an issue.
I wouldn't expect your hardware to overheat but since you've written you have no exhaust or intake, it might be a good idea to monitor your thermals. You can do so using msi afterburner. Also, if you don't clean your computer regularly, I might take a look inside and check if any dust has built up over time.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024664
well its the
well its the first time so i asume im safe
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024665
If it's "super old", it's likely starting to fail. A good PSU can last upwards of 10 years, but lower quality ones may only make it like 5 years or so. In any case, you're going to want to replace it, as it can potentially damage other components in your system.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024666
the temps are pretty uh-
idk how to say it but idel its like 38c+ and when i play roblox its about 80c under so idk if those temps are bad or good im fiarly new to hardware and im just a kid so e-
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024670
i asume
ty for the help
im not inirely sure how old it is sadly
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024673
Your CPU throttles at 73°c, so you at least need 1 intake fan. By getting a fan, you should also get slightly better performance
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024689
14 minutes ago, Sambadtech said:
i asume
ty for the help
Maybe it's time to give it a good cleanup.  It's always amazing how much dust they collect over time.
@Chris Pratt
How many PSUs for computers have you seen failing?  I have seen exactly two in about 30 years; one was plugged up with dust and therefore overheated, the other one failed after it had been running at 230V and then needed to work at 110V instead.  The latter was from Enermax, and they offered to replace it, but I didn't because shipping would have been too expensive.
If a PSU fails just like that after only 5 years, I expect to get it replaced under warranty --- and I'd probably sell the replacement because the quality is so questionable that I wouldn't entrust it with powering my expensive hardware any further.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024690
@Chris Pratt
Again, depends on the quality of the PSU. There's some PSUs that only have a 5 year warranty. Overall quality makes a huge difference. Just watching this forum since the pandemic has been enlightening, since there's been a noticeable uptick in people with PSU failures or other issues. The lack of availability combined with higher prices has led many to buy cheap no-name brand crap off Amazon, and well, there you go.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024725
@Chris Pratt
yea i did a clean up pretty rexently so its ok for now
but idk how much volts can my power supply can delever so im kinda stuck
is there a way to check?
true
soon ill be getting a new cpu too with prob more ram so yea
im already planing on aadding a exgost but nun the less ty for the recommdeation, sorry i cant spell crap caz im kid-
well im fairly sure this power supply is well over 5 years old and yea im guesing i should get a new one in the near future
unless my dad just buys me a new low end pc oof
https://linustechtips.com/topic/1378011-pc-power/#findComment-15024744
Who would buy a crappy PSU to ruin their expensive hardware?  It's also possible that people are using their computers more than they used to and their PSUs wear out faster because of that ...
@Sambadtech
A PSU supplies several voltages, and measuring them isn't so easy because you'd have to measure them under various loads.
You could ask your dad to buy you a used workstation off ebay.  That way, you can get a lot of computer for his money and
good hardware that doesn't give you trouble.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15025430
Plenty of people. I can't count the number of build planning posts just on this forum I've seen that had ballin' parts lists, except for a bottom of the barrel PSU. Not everyone understands how important a PSU actually is, and blow all their budget on the cool stuff like CPU, GPU, RGB, etc., and just throw in a PSU as an afterthought.
https://linustechtips.com/topic/1378011-pc-power/#findComment-15026296
