I'm planning on getting Beyerdynamics DT 990 Pros 250 Ohm, but I have no idea what amp or dac I should get. I'm not looking for something super duper high end, I'm looking for something basic and will power the headphones properly. Or if I should get a different pair of headphones like the Sennheiser HD 600s, I'd love to hear your suggestions.
https://linustechtips.com/topic/1377228-help/
Do you really need one? Just use them.
Max the volume. If they are too quiet, get an amp.
If you hear too much noise, get an external DAC.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1377228-help/#findComment-15019148
