can OS on old iPads be updated easier than on old Android phones?
ij7okCEu
Go to solution Solved by da na,
Welcome to the forums!
I'm not an Apple expert but I do refurbish lots of older iPads and iPhones for resale.
I can tell you that they can only be updated to a certain iOS version before they're limited in software from updating any further. Whatever banking app you use won't run on a first gen Mini IIRC - iPhone 4s which is a similar era can only go to iOS 9.3.6. I believe it is ARM86 based so most modern iOS apps won't support it
The mobile banking app requires Android 6. I've already been through this a year or two ago when the banking mobile app needed Android 5 and i had to buy another Samsung Galaxy S5.
Now it looks like the S5 cannot be updated from Android 5 without rooting -- a time-consuming task with no guarantee of success, especially on old, less popular hardware.
I've never used Apple but i can get an old iPad mini 1st generation with 16GB for $60.
Can an Apple ecosystem expert tell me whether those types of iPads can be kept updated so i can use modern mobile apps (just need mobile check deposit).
The other option is to buy a Galaxy S5 with LineageOS already on it with Android 9. I heard Apple devices have the advantage of being able to be wiped easier, while Android devices keep their device ID after factory reset (allegedly).
Please post what you think about those old iPads
if what you do in the bank app can be done in a browser you could could do it in a browser in android 6
mobile check deposit. can only be done on a device. i've tried emulators Bluestacks and BigNox, no go.
Thanks for the answer, i've found a list of last-supported OS versions for each generation of iPad.
https://www.techlicious.com/tip/how-to-update-an-old-iPad/
The idea to buy old iPad is a no-go, solved.
OK, good choice there.
I do have a suggestion of an iPhone 6. They can go to iOS 13 at least, I think they can go to 14 but not 100% sure, are decently usable today and could run that banking app. They're arm64 based and use the Apple A8 IIRC so they'll probably be supported for a little longer. Can be found on ebay for under $50 in OK condition. Heck, if all you need it for is online banking... you could probably find one with a cracked but working screen and broken speakers, camera, something like that for under $30.
Galaxy S5 has an official Android 6 update which you should be able to install easily. Unless your phone is from some carrier that doesn't release updates for their phones
Intel Core i9-10900X, Asus TUF X299 Mark 1, 64GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, Asus GTX 1080 Strix, 500GB, 250GB & 120GB SSD, 2x 4TB & 2x 2TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
