40" to 43" 4k monitor
King_PIN
I need a new monitor under $1k CAD or a couple hundred over if it's a big upgrade.
40-43" 4k.
No wide panels.
NO SAMSUNG
I don't care about sound, or stand as my desk mount arm can hold up to 45 lbs.
3840 x 2160
I currently have a 40" 4K Philips but it's quickly on it's way out as it has issues waking from sleep and is starting to flicker.
I have been looking at:
LG 43UD79-B
AORUS FV43U
HP Business Z43 42.5" 4K UHD LED LCD Monitor 1AA85A8#ABA
I really want something that is very good for day to day tasks so text needs to be clear.
I am not a heavy gamer but when I do play it's FPS.
Sounds crazy to say, but you probably want to stay at 40” or under for 4K, if you care about text clarity. The pixel density starts to drop below 100 ppi, which is pretty much your floor for not being able to see every pixel at a typical monitor viewing distance. Bigger TVs and such get away with it because the viewing distance is much greater, usually. It's also less of a concern for gaming or just generic media consumption, since your eyes tend to gloss over issues like low pixel density with that type of content. Where you feel it is in productivity and textual content.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
I agree.  40" is the perfect size for me and something I am used to.
Only reason I mention 43" is because 40" doesn't give a lot of options.
I really don't want to go smaller.
The LG looks to be out of stock, so you're really stuck between the other 2, I'd guess.  The 21:9 Dell is too expensive and probably too wide for what you want--and will be shorter to boot.
40" should be fine for text (i'm on one right now), but yeah, 4k is like "minimum standard" at this size, imho.  (Mine is AOC's sister to the Phillips 40" curved).
I really want to like Sceptre, but they are stuck at 1440p, which is unacceptable on 40".  But if you want to spend like HALF, it does exist.
C408B-QWN168W
C408B-QWN168W
Sorry what are you saying here?
LG is coming out with a 42" OLED in Jan 2022.  It was supposed to come out this summer but it was delayed.  I wonder if my monitor will last that long.  Otherwise, although it's way over my budget I started looking at the Acer Predator CG7.
https://www.thefpsreview.com/2021/08/23/lg-to-launch-42-inch-oled-gaming-tvs-in-early-2022/
