Help with .rigd extension malware thingy
HK007
So i opened a link from a random email, and basically it downloaded many programs and made all my files have .rigd ext. nad i can get my files back if i rename each one.
my question is, is there any script or program that can decrypt it from me cause i have about 200GBs worth of files i dont wanna go to every single one to rename.
edit: when i changed the .rigd file type i stll cant open those files
3 minutes ago, Benji said:
That may be because it's an encryption malware. Changing the file extension does nothing. It's useless.
Well, I guess you've learnt your lesson about clicking random bullshit on the internet.
Any website on the internet that you can find tells you that the decryption keys are apparently only on the servers of the people that infected you, so you can say goodbye to your files. Either you have a backup and re-install your OS, or you're out of luck.
i hadnt backed up my files from this pc and it had all the latest ones
thanks anyways
