Problem of a friend:
PC does not Post
No power to peripherals
All lights inside the PC seem to work like usual
Every component seems to work fine, swaping them out did nothing.
BIOS Battery is alright
Thank you very much in advance
Edit:
all steps in the pinned Post have been taken, without results
Parts:
AMD Ryzen 5 3600
Radeon RX 5700 XT ROG
ROG Strix B450-F Gaming
be quiet! Pure Power 11CM
Corsair Vengeance RGB Pro
OS: Win 10 Pro 64bit.
BIOS: ?
Edited by Couccun
missing information
https://linustechtips.com/topic/1375938-pc-not-responsive-no-output/
PC does not Post
Need specs.  Descriptions of types of information needed are in pinned posts at the top of troubleshooting as well as some suggestions on methodology.
sorry about that, i edited the Post accordingly, please tell me if something is still missing
Could use the wattage of the PSU.  Not perhaps as important in this case as in some because the cpu and video card are last gen, so transient spikes won’t be as big a problem.  Mostly it’s to see if there is enough power.  My memory is 5700xt equipped machines want 650w or more.
with ryzen2 after checking the various connections is to make sure that any difficulties with software are taken care of on a basic leve, make sure all parts have their drivers updated to the newest version and that windows accepts them.  Often this can mean just clear, update, and reinstall everything. Windows last.  Do not reinstal anything like overclocks or PBO. This produces a fresh bog standard system to troubleshoot (and may fix the problem anyway) If that doesn’t fix stuff we get to start playing hardware games.  I take it that it may post, but you don’t know because there is no output.  Assuming it IS posting and the video card is OK, the things to look at in order would be cable problem, monitor problem, motherboard problem.  As for the USB, that should work if there is no hardware problem and it is posting.
Edited by Bombastinator
