Need power supply suggestion
N14050
Hi. My current power supply died. So I need to buy one ASAP. My specs are :
Ryzen 3 3200g with vega 8 Graphics
Gigabyte A-320 motherboard
2x4GB 2666 MHz Ram
1 TB HDD
I have a very limited budget. So within the PSUs I can effort either I can get a normal 450 watt power supply or a better 200 watt psu. I'm thinking about going for the 200 one. Newegg PSU calculator says I need a 147 watt psu. As I don't have any graphics card and don't plan to upgrade any time soon I think 200 watt one will be enough. Which one should I choose?
2x4GB 2666 MHz Ram
1 TB HDD
PSU calculators are VERY rough, they should only be used to get very rough ideas of wattages.
Go for the 450, you'll thank yourself later.
2x4GB 2666 MHz Ram
1 TB HDD
Wait.. What is "normal" 450W and "better" 200W?
So your better 200W is actually 96W and the normal 450W is 192W. Those are utter garbage. What do you consider bad if those are good enough for you?
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti and RTX 6800 | Corshair psu
