Freesync premium making movement pixelated(?)
I turned this option on and I can see the pixels ingame on things that are moving. Is this setting useful enough to warrant enduring that? Can anyone test if they get the same thing?
x570 dark hero | 3950x | 6800xt rog hybrid | tridentz 3200 2x16 + 4000 2x16 | 1tb 980 pro, 512gb 970 evo, seagate 1tb wd 5tb | kraken x63 | dark base pro 900 r1 | corsair hx850i
https://linustechtips.com/topic/1375239-freesync-premium-making-movement-pixelated/
Everything you see on your display is pixels. Can you please try to better describe your problem?
Does your display support Freesync Premium?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Yes.
I can't describe it better, which is why I can't google it, because all the results are something else.
Basically little cubes(visible pixelation) on anything that has rapid movement on the screen. Maybe it's visible while recording, I'll test it soonish and update the thread if it does.
