  • Problem - Upon boot up there is a strange noise that sounds like coil wind but it goes away after a few seconds. This only happens the first time I turn the computer on for the day. There is also a smell of something burning but my cpu temp is at 30 and gpu is 37. This started happening about a week ago.
  • Operating System - 64-bit
  • System Specs - https://pcpartpicker.com/list/2JWLBc.
  • Tell us which BIOS version you have. Some problems can be fixed by updating to the latest BIOS, so check that there are no updates available
  • Include any software running when it crashes (if applicable) - Computer has never crashed.
  • Give full details of any error messages and screenshots if possible - Attached is a short video with audio of what it sounds like.
https://linustechtips.com/topic/1374993-strange-noise-upon-boot-up/
Fan is touching something, or bad bearing.
Check that the mesh filter isn't rubbing against any of the intake fans.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
Sounds like a bad fan, or something jammed in it? you could unplug which one it sounds like it might be coming from and see if it goes away. Then take that fan out and inspect it, possibly RMA it.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
  • Cooling
  • Operating System
    Windows 11
