Is there a problem with PhysX?
Go to solution Solved by TheNinjaNextDor,
Nope. It just means there isn't a newer version to update to.
After installing the new beta drivers, this page showed up, saying that PhysX couldn't be updated. Is there a problem?
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/137499-is-there-a-problem-with-physx/
I don't know about you but if you can read it says same or newer version is currently installed.
I was just making sure. Stop going off at people without any reason.
COOLING:
