Budget (including currency):$1000
Country: US
Games, programs or workloads that it will be used for: Fortinite GTA 5 Cold War
Advise. My 13yr old wants to build a Gaming PC and do his home work. I know I want to make it decent so we don't have to do a ton of upgrades later. With the GPU's costing as much as they are I was thing of using a AsRock B550 Steel Legend motherboard and a Ryzen 5 5600G. At least until the GPU's come down to reality. Thank you for any input.
Andy
https://linustechtips.com/topic/1374722-first-build/
Here is a reasonable list.
5700G, 2x8GB RAM at 3600 CL16 speeds, HDD, SSD and everything you need.
P.S. I choose case, fans and colors as my taste, So you can change those, Go cheaper if u wanted or even go non RGB variant to save good amount of money, But I assumed because of motherboard option, you wanted white build... 😄 I can adjust it as you want so tell me.
https://pcpartpicker.com/list/DdYWNP
https://linustechtips.com/topic/1374722-first-build/#findComment-15002154
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($258.97 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($129.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($74.98 @ Amazon)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($61.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Case: Montech X1 ATX Mid Tower Case  ($56.90 @ Amazon)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($88.00 @ Amazon)
Total: $720.82
Generated by PCPartPicker 2021-09-21 07:43 EDT-0400
https://linustechtips.com/topic/1374722-first-build/#findComment-15002229
