WILL MY PC EXPLODE?? HELP
Go to solution Solved by Pixelfie,
Don't see anything wrong, but if you mean the temps that's completely normal. Just make sure it doesn't go above 85 under load. My 5500 XT is like 65c idle (because the fan stops)
What PSU do you have? If it's a low quality one that can explode (still unlikely)
Probably not questions to ask yourself, why is the temperature so high is that normal for a GT 730? is it because the cooler on the card isn't up to the job (consider a custom fan curve) or is it the air flow in may case non existent (place a desk fan blowing at the front of the case if you get better temperatures you need to improve the case cooling).
In my experience (not GT 730) 81 degrees is normal for the GPU.
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
47°C is 116°F, which is within the thermal range of that card. The lower the temps the better, you could add more fans to the case, or see if there's a better fan. The GT 730 isn't a high-end card. I had a GT 710 and it ran at about the same temps as your 730.
I wouldn't worry too much unless it jumped up to 70°C or higher and stayed there continuously.
If it is overheating, there will be symptoms like black screens, freezing, video lagging/stuttering, etc.
I have a Geforce RTX 2060 which is usually running around 50°C.
You could install Open Hardware Monitor or a similar utility to keep an eye on the temps. I set up a widget that sits in the corner of my desktop so I can monitor the  temp of my CPU and GPU in real-time.
Just be aware that not all the utilities report the temps 100% accurately. A few degrees isn't cause for concern. 10s of degrees might be.
23+ yrs IT experience
MAIN SYSTEM
Operating System
Windows 10 Pro x64 21H1
Case
Antec Three Hundred Two Gaming
CPU
AMD Ryzen 9 3900X 3.8GHz 12-Core 24-Thread
Motherboard
Asus ROG Strix X570-E Gaming
RAM
G.Skill Trident Z RGB Series 32GB
(2 x 16GB) DDR4 3200 (PC4-25600)
Graphics Card
Asus Nvidia Geforce RTX 2060 Overclocked (Factory) 6GB GDDR6
Dual-Fan EVO Edition
Storage
2 × Samsung 970 EVO Plus Nvme (M.2 2280) SSD 1TB
2 × Samsung 860 QVO SATA III 6.0Gb/s SSD 1TB (RAID1 Array 1)
2 × Hitachi UltraStar HDS721010CLA330 7200RPM SATA III 3.0Gb/s 1TB (RAID1 Array 2)
PSU
Thermaltake Toughpower GF1 850W 80+ Gold
Optical Drive
LG WH16NS40 Super Multi Blue Internal SATA 16x Blu-ray Disc/DVD/CD Rewriter
Displays
HP w2408 widescreen 16:10 1920x1200 @60Hz
HP w2207 widescreen 16:10 1680x1050 @60Hz
Keyboard/Mouse
Logitech MK200 Wired Keyboard/Mouse Combo Kit
it's made by REDRAGON and IT'S 650 WATTS
OKAY THANK you.
I don't know what you mean but I will SEE.
Not sure what specific model, but Redragon doesn't seem to have a good manufacturer like Seasonic or CWT. If you can I would recommend a different unit, but the chances of this one exploding are still small.
  • 2 weeks later...
On 9/22/2021 at 10:13 PM, whm1974 said:
Has there ever been a case of PC exploding? Burst in Flames yes, but Exploding?
There have been some instances of course, but with modern hardware not so much, i refurbish computers on the side and i always get a new power supply from evga typically that have all the modern protection gizmos on them.
How far back area able to go? As far as PSUs are concerned?
