Anyone else having this problem with Shadowplay?
Go to solution Solved by chawndi,
Why do you need shadow play to use a mic, for recording?
Anyways there is known issues with "Nvidia voice" or whatever,  if you use that turn it off.
-Scott Manley, 2021
I use my microphone on shadowplay for most clips that either include conversation or so, have always used it and like to.
I don't have Nvidia Voice installed, and by that I assume RTX voice?
Yeap, I wasn't sure how its called, so its a separate install...hmm then you could try to uninstall Nvidia sound drivers *if* thats an option.
I just know there's issues with this rtx voice app though.
Ps: and if that fails DDU and reinstall drivers . I mean it  sounds like a driver issue to me either way.
-Scott Manley, 2021
I completely re installed geforce experience yesterday but i'll take a look at a complete overhaul of doing the sound drivers too.
