Budget (including currency): 2k GBP
Country: UK
Games, programs or workloads that it will be used for: Mc and blender and some pcvr
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): this is my parts list so far i need help with mobo and gpu stock (the 3070 ti is definate) -> https://uk.pcpartpicker.com/list/cghT2V
https://linustechtips.com/topic/1371914-new-pc-build-need-help/
I would get CL16 RAM. Your 5900x will thank you.
The Motherboard is a bit overkill, but the price seems fine for it.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980065
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  (£450.00 @ Currys PC World)
CPU Cooler: ARCTIC Liquid Freezer II 360 RGB 48.8 CFM Liquid CPU Cooler  (£94.99 @ AWD-IT)
Motherboard: Gigabyte B550 AORUS PRO AC ATX AM4 Motherboard  (£109.99 @ Box Limited) board you picked had pretty crappy VRMs.
Memory: Crucial Ballistix RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£161.91 @ CCL Computers) will help a bit more in performance.
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive  (£74.98 @ Amazon UK)
Video Card: EVGA GeForce RTX 3070 Ti 8 GB FTW3 ULTRA GAMING Video Card  (£899.99 @ CCL Computers)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  (£84.98 @ Amazon UK)
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply  (£72.98 @ Amazon UK)
Total: £1949.82
Generated by PCPartPicker 2021-09-09 14:01 BST+0100
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980087
5 minutes ago, Koder said:
Cool so a) can you reccomend a more cost effiecent motherboard and b) I would rather have 32gb rather than 16...
I agree 32gb is fine. Cl18 is fine if much cheaper than cl16. I would get a Arctic liquid freezer II 280 instead, unless you want rgb. Get another SSD thn the WD 550
Total: £1949.82
This! The arctic freezer is much better value and performance Also SSD should be fine. You can always get a gen4 nvme down the road.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980098
Just now, Koder said:
i had one a 850 but i didnt have the money yet... 😞
Should I buy and build the rest of pc and then when i get a gpu buy and add?
I mean, it's an option. The problem is that your CPU doesn't have an IGP, means it's functionally useless until you have some kind of GPU to put in it.
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980126
@Koder i would swap the AIO with a Arctic liquid freezer 360 AIO
I would swap the corsair ram with the Crucial ballistix 32 GB CL 16 and the Mothreboard with a MSI B550 Gaming plus
https://uk.pcpartpicker.com/list/z7JPPV
Here is the link
Overall same to better performance for a lower cost
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980130
Essentially, the longer you wait with your build, the better.
A new PC isn't much fun without a GPU, but in the meantime newer hardware might become available - so you might end up with either better or cheaper hardware by waiting - as a general rule of thumb.
I did find out however, that nvidia's site has a json file that you can use to monitor when their UK partner have new FE's in stock.
If you know scripting, it should be easy to monitor (did one before I realized that importing from UK would add additional import tax since brexit)
EDIT: This is the json I played around with, before 3080 Ti was launched:
https://api.nvidia.partners/edge/product/search?page=1&limit=9&locale=en-gb&gpu=RTX 3080&manufacturer=NVIDIA
Edited by helfisk
Added link
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980137
You should concentrate on buying the gpu first. There are some places that have bits of stock although prices are inflated.
The MSI board in your spec is one of the worst in terms of VRM. The B550 version is tons better. If you don't need wifi then the B550 Tomahawk is cheaper.
The Fuma 2 is a good air cooler if you want an alternative to an AIO. The Arctic Liquid Freezer as already suggested is good though if you want liquid cooling.
Avoid the WD Blue SN550 as they swapped out parts and it is a lot slower. The spec below has a Gen 4 SSD which will help if moving large files around. The WD Black SN750 is a good choice for a Gen 3.
Solid Corsair unit for a good price.
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  (£65.98 @ Amazon UK)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard  (£139.99 @ AWD-IT)
Memory: Crucial Ballistix RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£140.89 @ Box Limited)
Storage: Corsair MP600 Force Series Gen4 1 TB M.2-2280 NVME Solid State Drive  (£127.96 @ Amazon UK)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  (£83.99 @ Currys PC World)
Power Supply: Corsair HX Platinum 750 W 80+ Platinum Certified Fully Modular ATX Power Supply  (£95.04 @ Infinite Computing)
Total: £2003.84
Generated by PCPartPicker 2021-09-09 14:25 BST+0100
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980146
12 minutes ago, Mr-G-Man said:
also, you won't be aable to test whether the parts work, and could drive them out of rhe return period, only for u too realise it is faulty
This is a valid point - the CPU you are looking at, doesn't have an embedded GPU - so unless you have an old GPU available, you would essentially buy a very expensive but useless hunk of metal.
https://linustechtips.com/topic/1371914-new-pc-build-need-help/#findComment-14980158
