My friend recently bought a pre built pc. https://www.bestbuy.com/site/asus-rog-gaming-desktop-intel-core-i7-9700f-16gb-memory-nvidia-geforce-rtx-2070-super-1tb-hdd-512gb-ssd-black/6401065.p?skuId=6401065
When he goes to play warzone he only get between 70 and 80 fps. We cannot figure out the problem. Is the single channel memory causing the issue?
https://linustechtips.com/topic/1371775-trying-to-help-a-friend/
This is kind of meaningless without knowing resolution of graphics settings.
Single channel memory is shit. Dinky heat sink on an i7 with the usual Asus prebuilt Zero-Airflow Design™ probably isn't helping either.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
