cpu hitting 100% utilization randomly
puppo
i had this problem for maybe a month? i runned a cpu benchmark one day and the cpu utilization didnt go down, i dont understand why, on task manager nothing shows and i dont know why, can someone help me asap please? thank you
Posting your system specs would be helpful.. Have you at least restarted you pc?
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
i just did, still 100% utilization and 60°C on cpu
btw i have an i5 10400, coolermaster masterliquid ml240l, corsair vengeance pro 16gb 3200, msi b460 tomahawk, wdb ssd 500gb and a kolink enclave psu (600w)
Take a screenshot of your task manager processes tab sorted by CPU and share it with us. Let's try to see what software is using your CPU.
What benchmark did you run?
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
How do you know it's 100% utilized if task manager doesn't show anything?
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
6 minutes ago, puppo said:
-SNIP-
Go to the performance tab and show us the CPU section.
If task manager alone takes up over 25% then i bet your CPU is throttling into oblivion.
But as temps are fine this seems very strange.
im sorry, wdym by "throttling into oblivion"?
Your CPU is likely running below it's base clock for whatever reason. Give us another screenshot of the CPU section in the 2nd tab of task manager.
Just now, Stahlmann said:
Your CPU is likely running below it's base clock. Give us another screenshot of the CPU section in the 2nd tab of task manager.
Apparently not.
12 minutes ago, puppo said:
But what was using your GPU in that screenshot? You had a game open?
Also, you never answered what benchmark you ran.
What software do you have running in the background?
The "Apri Monitoraggio risorse" can also be a useful tool for diagnosing this sort of thing. It is linked at the bottom left of your task manager screenshot.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
2 minutes ago, HairlessMonkeyBoy said:
Apparently not.
the gpu utilization is because i have a live wallpaper (i only have igpu so thats why the usage is high)
ill be honest, i dont remember which program i used for the benchmark, i think the Home - UserBenchmark one, the only software that are running are microsoft edge (my main browser), steam, discord and wallpaper engine
