Ok guys so I built my pc and got everything working but it’s literally killing me because I can’t play it, I have a master liquid 240ml v2 rgb and my cpu is reaching 90 degrees, if I left it on I’m sure it would keep rising till I don’t have a cpu, ive tried re applying thermal paste and changing positions on the aio, I have it top mounted, the pump is well below the radiator, I don’t wanna front mount it because I don’t know how to take the front panel off, I’m bout to go to geek squad if I can’t figure this out and get charged like 400 for them to replace a cooler lmao help me please
https://linustechtips.com/topic/1370110-cpu-overheating/
Alright, dumb question first: did you remove any plastic that may have been on the cooler?
Is it mounted properly, making good contact?
Is the pump actually running? I think you should be able to feel some sort of vibration or hear some humming if you get up close.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967568
Yes but I’m not sure if it’s making good contact or not I don’t really know how to check that and I do hear a vibration is that air ?
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967579
You can take off the cooler and look at how the thermal paste has spread.
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967585
7 minutes ago, jaslion said:
Full system specs? (dont forget the case)
Where is the cooler mounted?
Maybe a picture of the pc's insides?
Intel i5 9500
EVGA RTX 3060
EVGA 650 +80 GOLD
gigabyte z390 aorus pro wifi
Mustex atx mid tower
coolmaster master liquid AIO 240ml v2 rgb
Samsung ram 16gb total
Samsung ssd 250 gb
blue western or something 1tb
dont mind cable management I honestly cannot fit all these fat ass cables in the back shoulda went with full tower
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967586
1 minute ago, damefr said:
I’m not really sure how it’s supposed to look I mean it’s spread but like a lil fucked up I feel like
You can post a picture of it, people can share what they think.
Another dumb question: are the fans spinning?
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967590
Yes they are butttttt I have my aio fans set to exhaust… I did some research and I heard that shouldn’t affect the cpu but maybe it is ?
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967597
post a pic of the therm paste and make sure the mounting brackets are not moving and is secure
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967604
Some basic triage/diag steps
  1. Do you see the Rad fans spinning & do you hear the AIO Pump running
    Little trick is to place a screwdriver on the face of the AIO and put the handle to your ear - it will amplify the noice inside the AIO pump header to check if you can hear the impeller spinning / water running
  2. Check thermal paste spread pattern
    When you remove the AIO from the CPU you should see a good coating of paste across the CPU face
  3. Check FAN & PUMP headers
    Looking at your main board you have 2x CPU fan headers & 2x PUMP headers - I would assume that the rad fans would connect to the CPU fan headers, and the AIO pump connects to either SYS_FAN5_PUMP or SYS_FAN6_PUMP headers
  4. Check the BIOS to make sure that fan/pump speeds are set.  Again looking at the manual, there is mention of 0 RPM running for the fan headers.  Might be worth checking to make sure the curve / temp settings here are OK
General suggestion online is to connect the AIO pump to the CPU header.  This way if the pump stops spinning (aka 0 RPM CPU FAN) then likely you will not complete POST so you have less chance to damage anything.
This would imply that the header used needs to be set to fixed RPM within BIOS or Fan control software.
Standard triage rules apply.
Check & change ONE thing at a time, then re-test.  This way you will know what fixed the issue.
Wanderer of the Internet.  Gamer of Games   Father of three
Relearning self-building, so please excuse the n00b questions for a while...
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967627
Probably it's wise to check the AIO if the pump works or not, as no water flow meams the heat stuck there. You'd probably feel/hear water flowing.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
AMD Ryzen 5 3600 || ASRock B450M Pro4 R2.0 Motherboard || MSI GeForce GTX 1650 Gaming X 4G || ADATA GAMIXX D35 2 x 8 GB DDR4 3200 MHz RAM || 480 GB Samsung PM981A NVME SSD // 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Deepcool AG300 CPU Cooler || Skyworth H27G30Q 2k 180 Hz Monitor || Logitech M650 Signature Mouse || Nuphy Air75 v2 Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: HP Elitedesk 800 G3 SFF
Intel Core i3-7100 || Hynix 40GB DDR4 || 120GB random SSD || 1TB Toshiba 2.5" HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14967631
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14968069
Looks like a good amount of paste applied.
next I would check BIOS for fan header speeds to make sure they are not 0.
Also check to see if you can hear AIO pump running when power on.
for initial short testing you could unplug all fans, just leaving pump connected to reduce noise in the case. Obviously don’t run long period like this
https://linustechtips.com/topic/1370110-cpu-overheating/#findComment-14969441
