i'm really out of my depth here
My pc is having random restarts from time to time. well, daily. no BSOD, just straight up restart. when i check the events logger this is the one i got:
WHEA-Logger
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Unknown Error Source
Error Type: Bus/Interconnect Error
Processor APIC ID: 0
The details view of this entry contains further information.
and this
A fatal hardware error has occurred.
Error Source: Machine Check Exception
Error Type: Cache Hierarchy Error
Processor APIC ID: 6
i did everything i know, but still keeps. happening.
from what i observe, it doesnt happen when i game or use the pc heavily. it checks out Cinebench on 30 in cotinuos or even Prime95. but when it is idle, thats when it happens. or even browsing or watching a movie. i really dont get it.
here are my setup/settings
5900x
x570 aorus master
gskill tridentz 4x8 @4000mhz Fabric@2000
Asus dual OC 3070
NVME 980 pro 1tb / sabrent 1tb
2hdds
lian li 011 dynamic with 9 more fans (sl120s)
dual monitor
auto OC via amd master but with bios settings
PPT 195
TDC 125
EDC 150
+200
Curve Optimizer Negative 20 on all cores.
my temps are pretty good right now so im really at a loss what is my problem.
thank you
https://linustechtips.com/topic/1370106-help-please/
.. Maybe, defective unit? Perhaps ask directly to AMD and probably ask for RMA?
Dunno if it works, but reinstall Windows can be a quick-fix if you're at loss.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
AMD Ryzen 5 3600 || ASRock B450M Pro4 R2.0 Motherboard || MSI GeForce GTX 1650 Gaming X 4G || ADATA GAMIXX D35 2 x 8 GB DDR4 3200 MHz RAM || 480 GB Samsung PM981A NVME SSD // 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Deepcool AG300 CPU Cooler || Skyworth H27G30Q 2k 180 Hz Monitor || Logitech M650 Signature Mouse || Nuphy Air75 v2 Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: HP Elitedesk 800 G3 SFF
Intel Core i3-7100 || Hynix 40GB DDR4 || 120GB random SSD || 1TB Toshiba 2.5" HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
https://linustechtips.com/topic/1370106-help-please/#findComment-14967623
Have you tried rolling back OC settings to see if standard operation works
Maybe one of the OC settings is just a little too far
Although is weird that happens at idle rather than at load.
I would revert OC settings first and test, then OS install and test, then vendor RMA if needed.
Assuming you have reseated all components & connectors just to make sure...?
Wanderer of the Internet.  Gamer of Games   Father of three
Relearning self-building, so please excuse the n00b questions for a while...
https://linustechtips.com/topic/1370106-help-please/#findComment-14967639
Clear CMOS and run at default specs to see if the system still crashes. This could be a bad overclock on the CPU that is causing the crashing. Is the BIOS updated to the latest non-Beta BIOS?
What make, model, wattage, is your PSU? How long have you had it?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1370106-help-please/#findComment-14967647
i already did it the windows reinstall. then did it while at stock.. im thinking maybe the 4000mhz ram and 2000mhz infi is the culprit. but cant know for sure. memtest perhaps?
https://linustechtips.com/topic/1370106-help-please/#findComment-14967667
im using a 750w silverstone. think that might be it? should i go higher  ?
is there any benefit to run my 4000mhz kit to 3600? i really dont have any idea
my OC with my 5900x is very modest. and technically it is for undervolting so im pretty sure its not the oc? i did it for lower temps. which is the case right now...
https://linustechtips.com/topic/1370106-help-please/#findComment-14967669
You can try memtest just to rule out this being a memory issue. It's worth a shot.
What model of a Silverstone is your PSU? Not all companies produce great units all around. You can try turning down the frequency to 3600 to see if your 5900X's integrated memory controller is the issue. Ryzen 5000 series had a sweet spot for 3600MHz.
https://linustechtips.com/topic/1370106-help-please/#findComment-14967681
i thought the problem sovled itself, but after gaming for 2 hours (APEX/PUBG), then did some R23,  i watched some youtube vids, then about 30 min in, it restarted again. no BSOD.
so right now, i ran everything at stock. (load optimized defaults via BIOS).
i checked the events logger, no WHEA-Logger error or notif since the restart. does that point to the XMP profile and/or OC?
https://linustechtips.com/topic/1370106-help-please/#findComment-14967852
i think i did it. still no errors on prime95/memtest.
but i put all my settings back one by one. but once i put on xmp profile (as by manufacturer) to 4000mhz, regardless of my Fabric, the WHEA errors pop out.
so i change the multiplier to 36 (3600) then run the fabric at 1800 for 1:1, error disappeared. i put the OC again, and still no error.
i hope this is  it. thanks !
https://linustechtips.com/topic/1370106-help-please/#findComment-14968663
