Possible broken graphics card - need help
My screen has a bunch of green lines and I tried to update the graphics card drivers and it pulls up a black screen. The first time I updated it it worked but now it doesn’t even update anything and a black screen pulls up and there are bright green lines everywhere all the time. The graphics card is GeForce RTX 3060. Processor is i7-10700F and it has 16 GB of ram. Power supply is thermal take Smart series 600W and Motherboard is Asus B460M+. This is a prebuilt pc by the way.
https://linustechtips.com/topic/1369938-possible-broken-graphics-card-need-help/
Sounds like the graphics card has indeed kicked the bucked. Considering it is a RTX 3060, it should be covered under warranty so exchanging it shouldn't be a problem.
As a side note consider getting a new and quality power supply. That Thermal Take unit isn't a particularly good quality one.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
