I have the b 450 f motherboard and I'm trying to plug in my front panel connectors and can't figure out which one I plug it into even with the manual after replacing my psu, power is in the pc it just won't turn on.
Motherboard pdf link- https://www.bhphotovideo.com › ...PDF
Web results
ROG STRIX B450-F GAMING
https://linustechtips.com/topic/1369892-pc-power-switch-help/
2 minutes ago, tkitch said:
From the top left, the power switch plugs into the third and fourth pin.
Buttons don't have an orientation, so there is no right way up.  LEDs do, so you may need to flip them, if they don't work first try,
I've tried, I just tried shorting the pins with a screwdriver which worked when I first built it but nothing is happening still.
https://linustechtips.com/topic/1369892-pc-power-switch-help/#findComment-14966040
okay stupid checks first:  (Because everyone falls victim to it)
1) The PSU is plugged in securely at both ends?
2) The PSU switch is turned on?
3)  The PSU is flipped to 115V (assuming US)
4) Both the 24 Pin & 8 Pin PSU connectors are hooked up properly?  (Not with a PCI-E connector, the CPU Header)
https://linustechtips.com/topic/1369892-pc-power-switch-help/#findComment-14966046
1)yes I've even took them out and put back in
2)yes
3) not us
4)yes
https://linustechtips.com/topic/1369892-pc-power-switch-help/#findComment-14966057
Did you reuse any modular cables from your previous PSU?
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1369892-pc-power-switch-help/#findComment-14966096
44 minutes ago, tkitch said:
then try this and see if the PSU works:
https://help.corsair.com/hc/en-us/articles/360025085372-How-to-Test-a-power-supply-unit
If the PSU works?  Your motherboard is probably not working.
If tried, how do I fix the motherboard then
https://linustechtips.com/topic/1369892-pc-power-switch-help/#findComment-14966183
