No, to me the 220t and the cooler master air cooler is is great for your build.  I say upgrade the ram to 32gb and seeing you only have a 1tb m.2 drive, I would recommend getting a bigger m.2 drive or like a 2tb drive with it. I only have two games apex and fortnite downloaded onto my 500gb m.2 drive and its already maxed out.
ok but would it be worth another 1tb 16gb ram and aio and o11 for my birthday?
Hey,
I saw that you're using a 360mm Rad. I would recommend a 240mm for that 10600k and the remaining budget on some RAM and extra storage. The case too, it's too big for what you've got going here, a simple o11 dynamic in it's standard size should fit well as the bigger one would show unused space as compared to the "snug" fit you'd achieve with a smaller one!
1 minute ago, Fvlcrum said:
Hey,
ok thanks. I think im gonna get the 360mm cause i wanna upgrade my cpu sometime to an i7 or i9. I agree about ram and ssd.
3 minutes ago, Fvlcrum said:
Hey,
Im gonna get the o11 to because looks.
33 minutes ago, Fvlcrum said:
No, I meant the standard o11 instead of the XL, would fit better with your current setup, but the XL might be good for upgrade down the line too!
Whats the normal o11? I cant find it on pc part picker which is weird.
