Been a while since I've posted on here but I definitely have a post worthy question.
I revisited an old OC that I have tested and run in my system very confidently. Now, I ran my 4.5ghz oc with an h100i and temps never passed 61C even after 12 hours of prime.
I have since switched to a full liquid cooling loop:
240 radiator EK
360 rad ek 64mm
2 ek supreme ltx acetal and nickel gpu block
1 ek supreme ltx cpu block
NOw temps for the gpu never pass 47c even under load. The cpu however pushes 63 on prime. Just seemed like it should be much lower.
Loop order is
Pump - gpu. - gpu. - cpu - 240rad - 360 rad. - res...'
https://linustechtips.com/topic/136974-2500k-temps/
you could have a bad mount, but the water is probably heated up quite a bit before going through the cpu- last part would be my guess.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1819736
GPU temps are better worse of the same? if higher, check for air trapped in blocks.
already a couple of SLI/CFX members had the same issues and was an air lock in
SLI/CFX bridge. makes the GPU crazy temps and exceptional CPU temps. what vCore?
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1820123
My GPU's are running great.  Idle around 26-31C and under load no higher than 46C nominally.  That was my thought, "could the GPU's be heating it up just enough to mess with the CPU temps under load."  CPU Temps at idle during an OC are same as always, 26C-31C, it's just those load temps that make me question it.
Now, this weekend I will be swapping from my c70 to 750d, and with that I have purchased an actual EK Backplate for my CPU block.  What I'm using right now is an older backplate, and I was afraid to put too much tension on the motherboard by cranking down on the CPU block.  To add to the variables here, how hard do you guys crank down on your CPU blocks when you're using a mounting system which does not stop you at a certain point?  Like the corsair mounts where they only let you tighten down so much in order to protect the board and also because it is calibrated to be efficient at that point.  Hope this makes sense.
In the 750D, I'll be changing the loop order to place a reservoir in between processors this time also.
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1821106
if your pulling the loop apart once you get mobo and cpu in, try testing it again on its own without the gpus or anything else see if it made a difference just by switching back plates and reseating the block
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1821218
Being tired this morning, now it seems obvious to do this, either way... GENIUS!!! Thanks! lol
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1821258
was surprised no one else ever mentioned it since your pulling the loop apart anyway :P
https://linustechtips.com/topic/136974-2500k-temps/#findComment-1821691
