Memory speed limited by CPU?
Go to solution Solved by -rascal-,
9 hours ago, CovidCid said:
I have an asus tuf b-365m
There's your problem.
B365 chipset based motherboards does not support DRAM overclocking.
You have a K-series CPU, but your motherboard is limiting you.
You need a Z370 or Z390 motherboard.
Intel changed their XMP / DRAM overclocking policy with 10th / 11th Gen CPUs with non-Z chipset based motherboards.
For any of the older generations, 9th Gen and older, you MUST use a Z chipset-based motherboard.
1 minute ago, CovidCid said:
I can't get it to boot normally with xmp
Then manually set it. Follow the speed and timing on the box, and set a higher voltage than what the box says.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I manually set 3600 mhz and CAS latency 16, however it would only boot into safe mode until I turned it to 2666. The box says 1.35 V, so how high should I turn the voltage?
You can go all the way up to 1.45-1.5V, but my tolerance for daily driving is around 1.4-1.42V.
1 hour ago, CovidCid said:
My bios won't let me go past 1.4 V. I tried every single timing from 3600-3200-3000-2933-2800 and only 2666 mhz will let the system boot. Do you think it's a cpu issue?
What motherboard do you have..
CPU/RAM/BOARD are ALL co sodered a factor for attaining the Memory Speeds (XMP) You paid for...
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
