10 minutes ago, Hunted0ne said:
Computer specs are :
Amd phenom 2 x4 965
4gb of corsair 2000mhz ddr3
Gtx 260 xfx
Ocz mod x stream Pro 600w
Gigabyte ht3.0 ?
300gb hdd
I'm not interested in changing to am4 just on how to get this computer running fast and for occasional gaming
Thanks for any help
Budget?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14955270
Define fast and what do you do for gaming? That CPU is 12 years old, and you'd need a miracle to be able to consider it "fast" in 2021. If you just need to be snappy, an SSD will help a lot, as well as some more RAM. It might also be a good idea to transition to Linux, something lighter weight like Xubuntu.
For gaming, you might want to get a newer GPU like a 750 Ti.
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14955272
Amd phenom 2 x4 965
Gtx 260 xfx
Gigabyte ht3.0 ?
300gb hdd
Thanks for any help
Overclock the sht out of the cpu, though you may need a better cooler
Swap that ancient gtx 260 for a better gpu such as the rx 460, 470, 560, 570
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14955467
Snappy is what I ment sorry and ill have a look at Linux and a ssd for the system and try and pick up a better gpu
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14955826
It had a flower cooler but it died would any decent tower cooler be fine ? And ill have a watch for those gpus
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14955827
Maybe look at a cheap 120mm 4 heatpipe tower coolers like the se 224 xt, freezer 34, pure rock 2, though if there are cheaper options such as those chinese coolers then you can also go for those
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14956054
Thanks after some hassle the gtx 260 turns out to have died (no surprise) is a 480 a decent replacement with my aging power supply?
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14956088
Rx 480 is a good replacement
If you are talking about the gtx 480?
Yea good luck powering that thermi nuclear reactor, not to mention cooling it
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14956134
True I know its power requirements are a fusion power plant but it was cheap ill have a look at the rx 480 though
https://linustechtips.com/topic/1368360-upgrades-for-system/#findComment-14956658
