First Pc Build
https://pcpartpicker.com/list/mPpHPV
Maybe something like this?
Ditched aio for a cheap aircooler cause no ocing
Cheaper board, same reason as the aio
Ditched rgb ram for faster ram so you wont have to overclock your ram
Swapped the obselete ssd for a faster and cheaper ssd
Cheap high airflow rgb case
Cheap but still decent 750w psu
Leaves 850$ for the gpu so maybe a 3070ti?
Basically cheapest but still semi decent build but also some rgb aswell, if done right rgb isnt a money pit
Youll also have to do this so the cpu can boost as long as it wants
Short tdp limit yeet tutorial to make your cpu boost as much as it wants
download throttlestop, pressing the turn on button, going into the tpl menu, set turbo long, short, and pp0 current to 99999 and shove the sliders all the way to the right, clamp, lock, apply, power limits yeeted
Youll also need to make throttlestop run on system startup since ts needs to be running to make the changes apply
