Graphics card questions
Go to solution Solved by Bhameck,
15 minutes ago, Dan Pablo-Techy said:
Is a zotac Gaming GeForce gtx 1660 super 6gb dual fan a good graphics card? It is pretty good value for how expensive graphics cards are now. I’m using a ryzen 5 5600x cpu as well and 32gb of G.skill tridentz ram. Does this seem like a good system.
     I wouldn't recommend buying that card. The card costs more than a 3070 right now, I'd recommend buying one of those scalped right now if you can. If you're on a tight budget, you should consider swapping out your case, ram, storage and mobo and upgrading later on. I had a 1660 super in my old system, and I built it for $1000. Considering your system is double the cost, your GPU would be the major bottleneck. Even getting a used RTX 2000 if you can would be a better option. A 2070 super costs around the same on eBay right now, so that would be a much better value, considering its retail is around 500 or so.
Welcome to the forums!!!
It all comes down to price to determine whether or not it is a good value.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
29 minutes ago, Dan Pablo-Techy said:
It cost $650 usd for the graphics card and the entire build costs $2,100 usd
Yikes!!! My RTX 2080 was ~$600 open boxed in Sept.2019... that's nearly double the cost of the card regularly if it weren't for the shortage.
Do you have a PCPartPicker list with the entire build in mind?? I wouldn't spend $2,100 for a PC with a 5600X installed and 1660 Super.
Do you have a PCPartPicker list with the entire build in mind?? I wouldn't spend $2,100 for a PC with a 5600X installed.
Yeah I thought it was a bit expensive but I couldn’t find anything better.
Here is the list - https://pcpartpicker.com/list/GF4sdD
I managed to snag a 1650 Super with my Ryzen 5 2600x back in June which was suprising for me, costed me abotu $530 for it all together
Gaming Rig:
Ryzen 7 7800x3D -30 Curve  | Thermalright Peerless Assassin 120 SE  |  ZOTAC GAMING GeForce RTX 4070 SUPER Twin Edge OC 12GB  | Patriot Viper Venom 16GB CL30 6000mhz  |  ASUS ROG STRIX B650E-F GAMING WIFI  | WD Blue SN550 1TB NVMe M.2 SSD, 2TB Samsung 870 EVO, 1TB Samsung 870 EVO, 2TB Seagate Barracuda HDD | Corsair 4000D Airflow  | Corsair RM850x Gold Series
https://pcpartpicker.com/list/dH78p2
You can fit a RTX 3070 graphics card in there for the right price. You can swap out the Corsair 3-pack of case fans for whatever you'd like. NZXT case will be a hot box and won't recommend.
Thanks
Thanks
Thanks
