Just wanted to double check if this was acceptable, I recently purchased a Thermaltake Pacific C360 Ddc Res/Pump 5V Motherboard Sync Copper Radiator PETG Hard Tube Water Cooling Kit CL-W243-CU12SW-A and I placed 8 fans on the radatior, from inside of the case, I have the fans in a  push motion and on the other side of the radatior, I have the fans in  pull motion as the exhaust side of the fans are sucking the hot air and blowing out of the back of my case. I just wanted to make sure if this sound like a good way to keep my radatior cool
https://linustechtips.com/topic/1367063-water-cooling-loop/
can we get a sketch?
from your desc hard to imagine...
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1367063-water-cooling-loop/#findComment-14948037
https://martinsliquidlab.wordpress.com/category/radiators/
https://www.xtremerigs.net/2015/02/20/pushpull-radiator-setups-learned-stop-worry-love-fans-less-noise/
for every 1.0 letter per minit you can do with a pump that too will decrees the temp by one degree.
not using 90 degree fittings and only using 2x 45 degree will help the lpm. 90 degree hard tube bends should be fine.
using fittings that dont reduce the id will help too.
using the same tube id as the fittings (bigger tube will decrees performance.
id tubing size dose not matter.
deliding will be the best cpu temps drop for the price but can damage it.
open air case will have better temps then any air flow case.
quick disconnect  fittings reduce the lpm (i think ek are hi flow but cost like $100 per set...)
not all duel, triple pump  tops work well. the ones that do cost alot.
Edited by thrasher_565
https://linustechtips.com/topic/1367063-water-cooling-loop/#findComment-14950625
