Budget (including currency): 600 Euros (The prices will be lover because I do not have to pay tax over the company name)
Country: Serbia
Games, programs or workloads that it will be used for: Gaming (1920x1080@144Hz), Programming, Video Editing, Screen Recording
I currently have:
- GPU: XFX RX 580 4 GB
- HDD: 2 TB Seagate ST2000DM008-2FR102
- HDD: 640 GB Western Digital WDC WD6400AARS-00Y5B1
- SSD: KINGSTON SA400S37240G 240 GB
- SSD: Apacer AS350 240 GB
- Monitor: AOC 24G2W1G4 (1920x1080@144Hz)
- PSU: LC600H-12 V2.31 600W
I want to buy:
- CPU: Ryzen 5 3600
- RAM: Patriot DDR4 16GB 2x8GB 3600MHZ Viper RGB BLACK PVR416G360C8K CL18
- Motherboard: MSI B550M MORTAR
- PC Case: MS Industrial ARMOR V715 GAMING
My questions:
- Will all of this work together without any limitations/problems in full capacity (For example, 3600 MHz ram with Ryzen 5 3600)?
- Should I buy a new power supply (If so, which one you would recommend for this setup)?
- Should I buy a water cooler later or the fan cooler is enough (If so, which one is the best price/performance)?
- Is the case good enough for my HDDs/SSDs?
PS:
I know that I will need to enable XMP with RAM for it to work with 3600 MHz.
Thank you.
https://linustechtips.com/topic/1366989-components-compability-and-suggestions/
Country: Serbia
I currently have:
I want to buy:
- CPU: Ryzen 5 3600
My questions:
PS:
Thank you.
the case has bad airflow get https://www.amazon.com/Montech-X2-Black-Mesh-Pre-Installed/dp/B08NDFV3Y5/ref=sr_1_2_sspa?dchild=1&keywords=pc+case&qid=1629562791&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFDSkQ2RERES0xBMlgmZW5jcnlwdGVkSWQ9QTAwNzc0NjIyUDZJQ1VRRlVKVURXJmVuY3J5cHRlZEFkSWQ9QTA3MTI5ODFRTTBGNzhTWlNKOFYmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
and you can get 3700x for about same price as 3600 now idk why
Everyting exsept the ram can i almost guarantee will work together.
And remember ram frequency is not everyting also look at the latency
The powersupply is totaly fine
I recomend a good Towercooler compared to a cheap AIO cooler, any bequiet or noctua cooler will be more then enough
And the case @Dk SPYder sent is better for airflow but you cant fit all of youre drives
Ram Compatability
https://www.msi.com/Motherboard/support/MAG-B550M-MORTAR#support-mem-19
Ram latency calculator
https://notkyon.moe/ram-latency.htm
CPU: AMD Ryzen 9 5900X
MB: Gigabyte Aorus Ultra Gamming X470
GPU: ASUS ROG GeForce RTX 2060 Advanced ed
RAM: 4x8 DDR4 G.skill TridentZ 3000Mhz
Cooler: bequiet! Dark Rock Pro 4
OS Drive: PNY CS3030 1TB
Case: bequiet! Dark Base 900 PRO Rev2.0
PSU: XFX PRO 850W XXX 80+ Bronze
My Steam Profile (from SteamDB)
  • Value: $3161 ($1003 with sales)
  • Games owned: 366
  • Games played: 293 (80%)
  • Hours on record: 9,679.5h
34 minutes ago, Dk SPYder said:
I do not have that case available here in Serbia, can you recommend me few of comparable cases.
Also, 3700x is 70 e more expensive than 3600 here.
Ordering anything over amazon here is more expensive than buying it at a store, because of the shipping fees.
Thanks.
Ram Compatability
Thank you.
I've choosen Kingston HX436C17PB3/16 HyperX XMP Predator, since it's on the ram compatability page.
The latency calculator says it's 9.444444 ns with CL-17 and 3600, and on 3200 CL-15 is 9.375.
Is that a good latency?
Thanks.
5600X is better in most cases than 3700X.
7 minutes ago, igor97 said:
Thank you.
Its good go for that if the price is right.
  • Games owned: 366
