Will the RGB header work?
Go to solution Solved by Latvian Video,
12 minutes ago, Ejo2001 said:
Hello!
I just bought a new AIO cooler, it's a MSI MAG Core Liquid 360R. I was wondering if the RGB header will work with my motherboard. I have an Asus X570-E. Am I good, or do I need to buy another cooler?
You will need to plug it into the ARGB headers, as shown in this pic
if the cooler uses the the standard 3 pin ARGB header you'll be good to go.  Just use Armoury Crate.  If not you'll have to have both Armoury Crate and Dragon Center running
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
Hello!
