Hi and thank you for clicking on my topic.
I know this question is asked a lot here, but i still need to ask it again. My budget is 100-120(max) $ and from my research i have narrowed down these headsets:
  • Razer BlackShark V2
  • Logitech G PRO X
  • Logitech G433 ( i checked rtings for reviews and somehow the G433 is better than Razer )
I am inclined to buy the Razer ones, but i am absolutely open to your advices.
https://linustechtips.com/topic/1365926-help-needed-for-choosing-a-headset/
5 minutes ago, Pixelfie said:
Out of these choices the Razer BlackShark V2. HyperX Cloud Alpha is really good too, probably even better than the others
My brother has the Cloud IIs They are pretty nice, and I have heard that the Alphas have better sound, so that would be even better
  • Logitech G PRO X
I Can say I have had many dealings with Razer and almost every headset in their line-up and ive never been blown away by anything past average. Logitech certainly has some great offerings and if it were me I would go with the G PRO X. It is probably going to cost you a bit more but its 100% worth it in the end. Additionally if you want to go a totally separate direction outside of those 3 You could look into beginner "audiophile" headphones like the SHP9500 or the AT M40x's both of which would fit comfortably within that price range.
