Not that long ago, I got some new memory for my pc:(https://uk.crucial.com/memory/ddr4/bl2k8g36c16u4b )
However, I cannot enable xmp while using this memory. If i enable xmp and reboot, I get 3 beeps and the pc wont reboot. This indicates a memory issue. I have tried changing the values (speed, latency, voltage) manually, but I still get the 3 beeps and it wont reboot. I can get the pc to boot again by clearing cmos.
The pc works fine when I don’t mess around with xmp or other memory settings.
The memory is in slots 2 and 4.
I am aware that this memory kit isn’t on the qvl list for my mobo (I didn’t check the qvl list before i bought the memory - doh 🤦‍♂️)
Is there anything I can do to get xmp to work or can I improve speeds and timings another way?
I am not that knowledgeable about memory, so any help is appreciated 🙂
Specs:
cpu - ryzen 3 3200g
gpu - zotac twin fan 1660 super
cpu cooler - amd stock
mobo - asrock b450 pro4-f
ram - ballistix 2x8GB ddr4 3600
psu - corsair cv 450
ssd - crucial mx500 500GB
case - cit f3
Thank You 🙂
https://linustechtips.com/topic/1365864-issues-with-xmp/
You can try to loosen the timings a bit, to something like 20-20-20-42
Or you can try to turn up the voltage to 1.4.
If that works, you can try tightening them again and lower the voltage step by step until it fails
The 3200g are Zen 1+, so a bit picky when it comes to RAM
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
https://linustechtips.com/topic/1365864-issues-with-xmp/#findComment-14936640
According to your Mobo website, it only supports up to 3200. So your memory isn't officially supported, so there is a very high chance it just won't work.
Edit: Of course you might be able to get it to work with the steps Tegneren provided, but it might require some tinkering.
Edited by richard1177
https://linustechtips.com/topic/1365864-issues-with-xmp/#findComment-14936645
Make sure you have the RAM in the correct slots. Usually 2 and 4 counting from the CPU side.
Nevermind. Missed that in my first read.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1365864-issues-with-xmp/#findComment-14936737
