Active backplate for 3080TI?
Solved by Skiiwee29,
The 3080ti has all its chips on the die side. The only reason the 3090 has problems is it has ram chips mounted on the back side and thermal pad/backplate are not really enough to keep them cool. Active backplate is not necessary unless its a 3090 OR the card had split chip, which is unlikely for anything other than the 3090.
6
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking15 -
apoyusiken ·
Posted in PC Gaming9
