I really need help here
Go to solution Solved by --SID--,
What make and model cpu, motherboard, NVME ssd and HDD?
On which sata connector is the HDD connected?
Check your motherboard manual. Some M.2 slots will disable some of the SATA ports on the motherboard. Usually it's for SATA M.2 SSDs not NVMe though. Try plugging the SATA cable for the HDD in to a different SATA port on the motherboard.
What motherboard do you have?
What SSD do you have?
I have a aourus micro atx motherboard and a crucial p2 nvme
What is the exact model of the motherboard? To be able to help I'd need to look up the manual for it.
If the motherboard has multiple M.2 slots which slot is the M.2 SSD installed in?
So I found it out the ssd is the problem the ssd stops the hdd from detecting/booting
19 minutes ago, Lagan said:
b450 aorus m
https://download.gigabyte.com/FileList/Manual/mb_manual_b450-aorus-m_1102_210615_e.pdf
Unfortunately I can't download the manual. It's possible Gigabyte's website is still experiencing issues from their recent attack.
Read the manual (it should be in your motherboard box) and it will tell you which M.2 slot to use and if any of the SATA ports would be disabled.
Try plugging the HDD in to a different SATA port. You might need to try a couple of different ones to find one that works.
I got it too boot but this happened
I got everything working thank you so much have a good one
