They're just random temperature sensors on the mobo. There's no way for us to say what they're actually indicating without at least knowing what mobo you have.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1365096-high-temps-please-help/#findComment-14931745
24 minutes ago, C-Horse said:
What are these high temps?
They are likely temp sensors that are not actually plugged into anything for example. They just report a constant number because they don't actually have anything "real" to report.
https://linustechtips.com/topic/1365096-high-temps-please-help/#findComment-14931768
Thanks, i guess that my would shut down if it was that high temps in it as well
https://linustechtips.com/topic/1365096-high-temps-please-help/#findComment-14931874
