Help me choose between these 3 gaming headset
Ya_Mi
I am in a very tight budget and there are a lot of dirt cheap gaming headset on sale on my local marketplace and i got 3 option
-HyperX Cloud (For $30-$35)
-HyperX Stinger (For $20-$25)
-Steelseries Siberia 200 (For $10-$15)
I once used a HyperX Cloud and i love the build quality and the sounds but for my option which is "USED", all of em are in a horrible condition like the headband and earcup is worn out and peeled out. The other 2 tho, are fine.
I am really attracted to the Siberia 200 despite of its horrible mic quality but hey, its $15.
So what do you guys think?
Behold the power of Chuck Norris the forbidden one.
personally I ewould go wiht a cloud they are fairly popular so if you need replacement pads they are really easy to source for fairly cheap but that is extra money
If you are on a tight budget, spending more money for a headset that is in worse condition and will require you to spend still more money to replace parts makes no sense.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
aggreed Imo I would just talk to the sellers in this case and drive downt he price. I will say if the clousd stinger is available its not too bad of an option at this price its not really that great but it doe its job fine. I really just would compromise to the point where the mic is actually awful
That's where you're wrong, i don't want to spend more money to replace the parts unless i go with the Cloud probably that is cuz they're in a horrible condition.
As for the Stinger and Siberia tho, they're in a good condition, some even have brainwavz earcups installed on them.
PS: I DON'T HAVE A HEADSET
I was rebutting the post above yours that said to buy the Cloud because replacement parts for it are easy to find.
Then you should've use "Quote"  so that i know you're responding to him.
Anyway, which one do you prefer?
