i have a 9700k oc to 5ghz, red devil 6700xt, and 32gb of ram two different sets tho(2133mhz i could do 3200 but im not sure if it would change anything). and whenever i play rust medium settings at 1440p my fps drops to like 40-50 fps and usually it sticks to like 60-70 fps and when i watch youtube benchmarks alot of people are getting way over this. i dont know what to do
https://linustechtips.com/topic/1364912-help-me-please/
If you can enable XMP and set the frequencies to match the RAM kit, you're going to gain some additional performance that is just laying on the table.
Have you tried to reinstall graphics drivers?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930641
just enable XMP of your RAM to 3200mhz...must do the magic
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930666
nah i havent tried that yet
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930669
I'd try that to see if performance increases. What RAM kits do you have exactly that you're trying to mix?? Generally, it is not recommended to mix RAM kits for these reasons and if the kits have different timings, they can be problematic.
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930681
i have corsair vengeance rgb 3200mhz and ripjaws v 3200mhz
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930686
48 minutes ago, Ghostly224 said:
and i have before but when i do my motherboard gets a red light and im guessin its because its two different ram sets. but both go up to 3200mhz
is your pc booting up when both the RAM's XMP is enabled?
if then you can just have it enabled
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14930728
The timings of both kits might be different at 3200MHz. As a result, they will not work as well together at these speeds and 2133MHz is the default frequencies for DDR4.
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14931209
could the ram speed be the reason im getting lower fps then what i see on youtube?
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14931557
No, I don't believe the problem here is due to the RAM speed. Have you tried running the system with just a single kit and see if performance increases once you enable XMP?? Just want to see if the other, different RAM kit that most likely has different subtimings are affecting your performance.
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14931562
im going to try to run my system with just the corsair kit with xmp on
https://linustechtips.com/topic/1364912-help-me-please/#findComment-14931579
