3 hours ago, jaslion said:
Try it with the stock cooler and if it's too loud get a aftermarket cooler? Doesn't have to be an expensive one a hyper 212 or similar is plenty good.
I'm not worried about noise. I'm just thinking about thermal performance. I'm trying to avoid the process of removing the stock cooler later which is a bit of a pain when you consider the process for applying a new one when the motherboard's in the case.
https://linustechtips.com/topic/1364653-ryzen-4650g-cooling/#findComment-14929053
