So i want to use an ethernet cable for my pc but i can not run a cable throughout my whole house as the router is in the living room and wifi is an awful option so would an ethernet cable connected to a power line adapter be a good idea for someone who doesn’t need competitive internet? And is there a good cheap option around $30-$35?
https://linustechtips.com/topic/1364610-power-line-ethernet/
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/1364610-power-line-ethernet/#findComment-14928569
Power line adapters are hit or miss. If the adapters are on the same circuit they work the best. If you have to cross a breaker or two you will likely get slower speeds. If you need to cross a phase it likely won’t work very well. High draw appliances can cause interference.
https://linustechtips.com/topic/1364610-power-line-ethernet/#findComment-14930346
