Stock or 3rd Party Air Cooler for itx build?
Solved by Gohardgrandpa,
3 minutes ago, bappled said:I’m going to be using some NZXT ones from my previous build, I believe they’re called the AER P 120mm fans.
Would those pose an issue?
I don't know anything about those fans. As long as you have a few and they are decent you shouldn't have an issue.
I love cases that look like the one you picked, just watch the dust build up on it.
