I would like to build a NAS to use mostly as a plex server, and also for some desktop backups. I would only need to be able to stream on one device at a time at 1080p. This would be my first time building a NAS server.  Could someone please recommend a good build for this use case? Budget is $300-350.
https://linustechtips.com/topic/1363445-first-nas-build/
31 minutes ago, DaurisSmith said:
Drives would be in addition to the budget, and I would prefer to do a new build. I am open to trying unraid for the first time for the OS, was curious what sort of advantages that would afford over using windows for an OS.
How many drives and what capacity?
Unraid is nice as it lets you mix drives easily, gives you a good webi nterface, and is just pretty easy to use.
How about something like this?
PCPartPicker Part List: https://pcpartpicker.com/list/g6gKvf
CPU: Intel Celeron G5920 3.5 GHz Dual-Core Processor  ($64.98 @ Amazon)
Motherboard: Asus PRIME H410I-PLUS/CSM Mini ITX LGA1200 Motherboard  ($106.65 @ Newegg)
Memory: G.Skill NT Series 8 GB (1 x 8 GB) DDR4-2400 CL15 Memory  ($34.99 @ Newegg)
Case: Fractal Design Node 304 Mini ITX Tower Case  ($89.99 @ Amazon)
Power Supply: EVGA BR 500 W 80+ Bronze Certified ATX Power Supply  ($48.25 @ Amazon)
Total: $344.86
Generated by PCPartPicker 2021-08-11 17:14 EDT-0400
Just add drives and your good.
https://linustechtips.com/topic/1363445-first-nas-build/#findComment-14926079
